CO2 as Shielding Gas
  • CO2 as Shielding Gas
    I was just wondering if it were possible to MIG Weld Aluminum and Stainless using CO2 as shielding gas ?
    The long version or the short version, NO!
    The easiest way to remember is no gas with oxygen in it for Aluminum. Use either Argon, Helium or some combination of both.
      Big time no with the alum, only argon or ar/he mix. as for ss, i'm not sure, i haven't tried it, but i think i'll stick with my straight ar for now.
      bc
      BC
      Coolmate 3
      MM210 w/3035 spoolgun
      Cutmaster 101
      LC1230 12" Metal Cutting Saw
        argon
        will argon work for ss and aluminum? or is there a mix that will work well on bolth.(trying to limit the # of tanks)
        thanks for the help
          Argon will work for both Alum and SS in Tig applications, as for mig, i believe you have to use Ar/Co2 mix for ss and for alum mig it's straight argon as well.
          BC
          BC
          Coolmate 3
          Cutmaster 101
            Howdy
            For aluminum MIG of aluminum the most common is straight argon. No co2. c02 will oxidize the aluminum which is why you use sheilding gas in the first place. For stainless the best are tri- mixes like Helistar A-1025 it has helium, argon, and a tiny bit of co2.
            Dynasty 200DX With TEC Superflex 9 & 17 Torches,
            Hypertherm 30A Plasma
            Rincoln SP130T Mig
