5F GMAW Pipe to Plate cert?
  • 5F GMAW Pipe to Plate cert?
    how is a 5F GMAW Pipe to Plate certification inspected
    for pass/fail?
    is it x-rayed?
    is it etched?
    how do they inspect for cold welds?
    "The best way to change someone's mind is with a rock"
    ASA member since Aug 2001
    American Sand Assoc.
    I think they would probably use destructive test to check the weld on this one. Most likely cut a piece out, polish it and test for sidewall fusion, root penetration, porosity and underbead cracking. I'm only going off what we do here in Australia when it comes to testing our assessment pieces.
    Andy249
    "Its the way it spatters that matters!"
      Australia Andy is probably right, Here, for F plate test, they just have you use 1/2" plate and put in at least 5/16" fillet on one side, then they put in a press and break whole 8" piece, no cutting needed, if they see penetration the whole length and no porosity/inclusions you are good for D1:1 unlimited thickness fillets. Paul
      More Spark Today Pleasesigpic
        thanks for the responses ... but this is Pipe to Plate ....
          D1.1 calls for macroetch only.
          JTMcC.
            JTMcC.
            Can this detect COLD WELDS ?
              What is your definition of a cold weld Frog? A visual inspection of the weld piece will often give a few clues in this direction. Poor sidewall fusion can be a symptom of a cold weld as can lack of root penetration, although, lack of root penetration can also be thanks to too lower travel speed.
              Andy249
                That is all the info I received. The cert failed for cold weld ....
                nothing else ... I ran 20 + certs and our Instructor helped choose the best one .... It "looked" sound. Full penetration, nice heat patch on the back side of the plate, nice weld wash up on the pipe, nice bead thickness .... just can't understand "cold weld" ....
                I would yhink the only way to really tell is by x-ray, but I was informed that there wasn't an x-ray done???? so how could the inspector tell w/o x-ray?
                  FrOg,
                  Maybe referring to cold lap where when the bead was continued there was insufficient penetration at the intitiation point of the tie in. Sometimes this can be detected visually. Can you talk with the CWI who tested the coupon?
                    Good point Hawk.
                    If that seemed OK then it may have failed sidewall fusion. I've seen welds that look ok on the outside but have little to no sidewall fusion. I don't believe you would need to X-Ray to see this, just cutting a cross section of the weld, polishing it and etching it would show if the weld penetrated beyond the zone of the weld prep.
                    As Hawk said though, anyway of talking to whoever tested the piece? It would be really frustrating to receive back such a generic comment!!!
                    Andy249
                      frustrating is the word .... can't fix what I don't know is wrong ...
                        Originally posted by HAWK
                        FrOg,
                        What makes you think a CWI tested the coupon?
                        JTMcC.
                          well I hope he did, all of our certs are for structural steel applications, and they have to be done through an AWS CERTIFIED WELDING INSPECTOR ... the union halls here in AZ are pretty **** about this .... I'm just frustrated now .... he cannot provide proof of the inspection .... just the initial results ... I was told the CWI does not "save" the specimens sent in for Inspection ... so now I just have to pay another $125.00 to try to re-cert .... hopefully with a better explanation if it fails next time ... or it's another $125.00 ... and the whole thing starts over and over and over again ... ugh ....
                            AWS welding qualifications don't have to be done by a CWI. Neither do API or ASME.
                            They often are, but just as often aren't.
                            JTMcC.
                              great ... more junk .... so you are saying that possibly
                              the person who is "Certifying" me is not certified himself
                              through one of the majors ? ... great .... more ?'s
