I've just got a spolgun and tried my hand at aluminum welding. I cannot get a decent bead for nothing. I'm an avid stick and mig welder in ss and mild steel and this is really driving me nuts..I know tig would produce better results but I'm building a boat and would like to finish before I retire.My setup is a Miller 251 with the 30A spoolgun. Running a positive electrode with 100% Argon. Any advice,suggestions, or tips would be greatly appreciated. I've done a lot of practicing and have buried my practice pieces 4 feet deep so they cannot be found with a metal detector. Not too proud of them. Is that deep enough?
Rookie needs help
Hi, I have run the same gun on a 251 as well as my xmt304 with great results on both spray and SS modes. If you give some more detailes as well as your settings and wire types I am sure you will get all the feedback you need to make sound welds. Good Luck, JEFF200DX 350P 625 Plasma & other stuff I forgot
More Details
Definately try changing the wire you are using to a 5000 series wire. Marine grade aluminium is an aluminium/magnesium alloy, as opposed to the aluminium/silicon based alloy you are currently trying to use to weld with. I saw a guy run this setup on a pulsed MIG and the welds were very poor to say the least! You can forget about any kind of positional welding whilst using this combination! Try changing your wire to marine grade and try again.
A stainless steel wire brush and acetone are the best way to clean your aluminium before you weld. Don't use anything but a stainless wire brush as the others leave impurities on the ally which will result in a poor finish.Andy249
"Its the way it spatters that matters!"
Just to cover the basics, with Alum it has to be clean. The worst Alum that I ever had to weld was refrigerated semi trailer floors. Always seemed to be animal or vegetable fat on it. And the insulation would outgas when heated and ruin the welds. If your weld turns out black you have a contamination problem or your gas is being blown away. Another thought, did you purge your hose? If you had air or previous mix gas it would be rough. Aluminum settings are more sensitive because the metal melts differently but once you get the hang of it you will love it. And with Alum it reflects the arc way more than steel so cover up, you burn much quicker.
Types of wire
I use 5356 series wire on all my marine grade aluminium welding. Aluminium is a fantastic conductor, and as such you need to weld with a fair bit higher amperage and wire speed to compensate. Generally spray arc is the way to go with this stuff! This of course means that your travel speed increases alot as well!! I far prefer fabbing with aluminium as it is so much faster to weld and cut for that matter.
I just found this site which puts welding aluminium in a nutshell pretty much.
http://www.twi.co.uk/j32k/protected/band_3/jk21.html
I have gained my aluminium welding experience from doing quite a few years of it in the workshop and also doing my certification courses.
Good luck with it and keep us informed!Andy249
Andy249 is on the ball with the 5356 wire. It lays in different but welds almost any AL. I work in an Aluminum shop and all we mostly use is 3/64 5356 wire. I would recomend .035 wire because you may need to go into short arc. Also set your gas flow rate to about 40 cfh this will help keep in cleaner.
