Just get a bottle of argon to start. If you are satisfied with the results you could get a teflon liner and different drive rolls but I personally think they are a waste of money. Good luck. Scott.
Spoolgun and controller would be my choice! Running Al through a regular mig gun is a bit difficult, due to rats nesting. I have the mm210 w/spoolmate 3035 and it works great, so that would be the better setup, but that is my $.02 worth.
Peace,
Yes i would diffently suggest the sga 100 and spoolmate 3035, is the best set up for you to do alum, not only that but you don't have to keep changing the wire ea. time.
guys. i can run 4043 wire through my 135 with teflon liner NO PROBLEM. with NO reguardes to the gun cable straightness. i sure would like to see how a 175 machine would burn this wire.
