Hi,
Can someone tell me if there is an 800 phone number to contact Miller about a warranty issue. I have had my MM210 since June of 2003 and finally got it hooked up to C25 gas a couple weeks ago. It worked great at first, but I noticed that as time went on I had to keep increasing the gas pressure in order to weld the same metal thickness as I had been welding, and I am going through an extra ordinary amount of C25. When I started working this morning before I turned the radio on, I heard a hissing sound and just assumed it was from my air compressor leaking. Checked the air compressor and lines and all seemed ok. Then when I was standing next to my MM210, I could hear the air leak better. I then put my ear next to the regulator and discovered that this is where the leak was, and the source of my problems. I won't go to the dealer where I purchased the MM210 because I think they are in the final stage of going out of business and I don't want my regulator lost in action in the event they do go under..........thanks for any info you can provide.
Pat.
Pat.
