Can someone tell me if the 350P uses true spray or is it globular transfer called spray? Thanks
350 P spray or globular called spray
The 350 will do both depending on the voltage you set. Globular is just not quite into spray. The "P" stands for PULSE and it is a pulse spray of two different currents called peak and background. There is more to it than that but that's the jist of it. A spray can be done with most CV machines and the right gas (usually containing over 90% Argon).
The Pulse spray allows for better out of position work while a full spray is better for flat work.
A-
