spool gun off of trailblazer
  • spool gun off of trailblazer
    Some oneasked about this a while back,i would like to run a spoolgun off of my trailblazer 301g.i have used the big spoolgun off a miller 251 mig machine.i know i need a control box for the 14 pin recp.but how do i set the wire feed speed?does the control box have a digatal readout?its been a while since ive used the spoolgun but i believe the wire speed control was at the bottom of the pistol grip.The trailblazer is a great machine.i would just like to use it to its fullest ,instead of buying a mig machine for aluminum.
    The Spoolmatic® 30A Spool Gun should work...
      10-4
      The Spool 30A has wire speed control on the bottom of the gun handle. It is not digital so you will need to experiment on the settings.
      Andy
        I'm haveing the same problem whenever I need to use my Miller Spoolmatic 4-pin without a weld control box with a Miller 300xmt 14-pinout-So far have not been able to find any adapters or work-around solution-
        Good luck
          boilerman79,
          Just dial in the voltage on your trailblazer. Each wire size has a sweet spot. I shoot for that voltage, connect the 30A via a WC24 and adjust the wire speed by the gun handle as Andy mentioned. It is a great set up. I ran one for quite a while: TB301G, WC24, and 30A.
