I work at a shop where we do stainless steel fabrication. Usually 14 to 11 gauge material. We use TIG welding, but when we do 7 gauge or 1/4 inch material, the boss wants us to stick weld it because he says stick welding is stronger than TIG, a few of us think that he is wrong, and by using lots of heat and thick filler rod, TIG is just as strong as stick. Who is right, and who is wrong?
TIG vs STICK
Welcome justweldit.
It would depend on the application but... as a rule, TIG is a beter more complete fusion if done right. Stick is faster and easier at those higher amperages and can also have it's faults if done wrong as well. It's easier to tie in toes and control travel speed with TIG and for multi-pass work, TIG can usually be done right away without chipping and grinding between passes.
Hope this helps.
Andy
