Could someone post a pic of the plug that comes with the MM251. I have a 250V/50A NEMA recepticle now that I use for a PowerMax600. I was wondering if the MM251 can use the same outlet. I have it wired with AWG6 to a 50amp breaker. Thanks, Jim
MM251 plug
Hey Ripshot,
That's exactly the setup I'm using with my new MM251. However, you might want to check your input amperage. The owners manual calls for a 50A breaker if you've got at least 230A. If you're getting less, you should use a 60A breaker.
Alex
(love that sound of fryin' bacon)
CORRECTION to the INSANE reply above:
Substitute "input voltage" for "input amperage" and "230V" for "230A", and suddenly it makes sense.
Obviously I've got to:
1. Have another cup of coffee
or
2. Hire a proofreader
before I click on the SUBMIT button.Be cool,
Alex
FREEDOM ISN'T FREE
SUPPORT OUR TROOPS
Ripshot,
Don't quote me on this, but I think it's an amps vs volts thing. If you've got less potential (volts), you're gonna suck more current (amps) to get the same output. Amps x Volts = Watts.
Anybody else have a better/clearer/more correct answer?
AlexBe cool,
Alex
FREEDOM ISN'T FREE
SUPPORT OUR TROOPS
