If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
did you make the goat feeder ?how many goats you got ?the wife thiks they would be fun. she cant get enough pets,we got puppies on the way ( bulmaastif's) 10 chickens and 9 cats (all cats outside keeps the field mice away from the house)
you would think that with only an 8ft by 12ft welding area i could keep it spotless but my shop is all choped up i got a 8x12 welding area (welding screen door) then a 12x20 main shop with all my wood working stuf and offic area (LOL a desk ,file cab. and comp)the main shop also has to house my materials (and heater its cold here in the winter)had to put my welding cart outside just use it to take welder out in the yard anyway as ny welder lives under my welding table.thats 3ft x 5ft and an inch thick lol took 4 people to get it in but you can do anything on it. it takes up most of my welding space but well werth it.i can weld stuff to it and plasma cut on 1"square tubes on top of it so it works out prity good ill have to post ya a cleaned pick.
well that turned out to be a book.
wheels that there is spotless compared to mine let me see if i cam find the part i cut off the picture for ya . LOL
i have to admitt it is wers than it has been in a long time but you should get a kick out of my disaster.realy unsafe to have it this way ,and slow to get anything don but i just finished a project and it is clean now.
I have done plenty of designs of that, or even greater intricacy and have had great luck with a die grinder. I have a ball and cylindrical bit for it as small as 1/8". For your designs I would get a 1/4" and a 1/8" cylindrical die grinder bits. I think the shank size on all mine is 1/4". You can look at them online at the Eastwood web site. I buy mine locally, but I think I have seen them in thier catalogs. For smaller than 1/8" gaps I would use a dremel tool.
BTW nice work.
this might help to show why i cant use the normal stuff to file and sand. here is a pic of 1 of the things im making this being a medeum size (pic of table version in the "need more pic's post" )
well it gives me somthing to do anyways
