Connect a spoolmate 3035 to a TB
  • Connect a spoolmate 3035 to a TB
    I have an older spoolmate 3035 that is on my MM185, from when this was the latest and greatest thing. I would like to know what it would take to connect this gun to my Trailblazer 251g. It has the 14 pin connector, I just am not sure which magic box to use to control it with. Any advice would be appreciated.
    Walker,
    You can use the SGA-100C adapter box. It will plug in to the TB251's 115 outlet. Then run a weld cable to the contactor inside the adapter box, connect the spoolgun weld cable to the other side, turn the TB251 contactor (on) and weld away.
    You could do it with a standard SGA100 but you would need to make an additional cord for the 14 pin connector to run the solid state contactor in the machine.
    Good luck
    Andy
