im running at 35 right now but wondering if i can drop that a bit as i have a 155 tank and have used a 1/4 tank on less then 2lbs of .024 wire. is this right or can i drop the presher to save a little gas.well i started at 8000psi now at 6000 i would gess thats 1/4 tank. im using it on a little mm135 on 10 gage or less
gass presher for mig
thanks for the help
[email protected]
JAMESTags: None
using 75/25 gasthanks for the help
[email protected]
THANKS
book said 20 to 30 i am at 30 not 35 my mistake too many pain pills or bad memory or bolth . i just wonderd what would hapin to my weld on the low side. or if you all thought staying on the hi side was good or bad . ill drop down to 20 see how that runs thanks.
happy weldingthanks for the help
[email protected]
I have always backed off on the pressure until I see the bubbles starting in the weld and then go back up just a little. The gage settings are just a reccomendation, the gun and your style of welding will control your best setting. Also if you have ANY air moving around you that changes the settings too, you need to increase for that.
Even back when I didn't have to pay for the gas I hated to change the heavy bottle so I was conservative.
thanks
i droped to 20 and is doing nicely thanks it should last a lot longeer now and is welding sweet.thanks for the help
[email protected]
thanks
i droped to 20 and is doing nicely thanks it should last a lot longer now and is welding sweet.
LOL gota wait a sec. administer said i can only post 1 time every 30 sec. gess i better type slower or not ask so many ????
thanks for the help
[email protected]
TimW:
I tend to adjust my style to match the chart centerline that way I know the setup time and time again and if something has changed, normally it's me not the equipment.
When I run into something wierd then I stray from the middle of the road, but its an analytical decision and controlled by changing only individual perameters at a time, to achieve the desired effect.
I weld for pleasure,
