Looking at getting a spoolgun for aluminum, but was wondering if it will provide any advantages when using steel wire as well? In short, help me justify purchasing one
You can run any wire you want through it. Spoolguns usually have longer cables than a MIG gun, so you get more reach with them. Nice for when you can't get the welder close enough, especially if it's up high.
Be well.
hankj
...from the Gadget Garage Millermatic 210 w/3035, BWE Handler 210 w/DP3035 TA185TSW
A spool gun has the advantage of having a long reach. My Regency200 has a 30a spool gun with a 30ft lead. This set-up is great getting to places on the trucks I repair, but it has its drawbacks in the size of the gun(sometimes impossible to get the proper angle in tight places).The gun is also tiring to hold with a 2 lb spool!!!
If I didn`t need a spool gun for aluminum I would NOT have it as my only means to feed wire.
A welder with both a spool and a regular gun will be my next reason to save,save,save.
as hankj said you can run just about any kind of wire through them.. even fluxcore... the 30A on my Trailblazer gets an awful lot of varied use... as well as Aluminum...
hope this helps
Heiti
Wheels... we must have posted at the same time... you are right about awkwardness... but lacking a suitcase feeder on the truck it sure does come in handy....
since wire doesn't like to be pushed more than 15ft, having a suitcase allows you to keep the power source a ways away, but the arc close. So, you could have a 30ft power cable, so then you're 30 ft away from the power source, and then 15ft of gun, so you can 45ft away, and still get great feeding with a normal mig gun
Guys
a suitcase feeder allows the use of a standard mig gun which will give you the ability to get into smaller spaces at akward angles and is smaller and lighter... thus less fatigue... but for aluminum it can be marginal... as the wire will like to birdcage from time to time.... the best compromise might be something like the XR pushpull system... or one of the old cobramatic systems.... the spoolgun gives you surefeed of aluminum wire albeit at a weight and size penalty....
Heiti
Pepsiguy;
One real benefit is that change over in my spoolgun is quicker than my regular mig. Since specialty wires often come in small spools 1 and 2 lb it is a snap drop it into the spoolgun. I use fluxcore SS dualshield from time to time and this is a great setup.
Peace,
On my MM210 I keep the spool gun loaded with .023 wire, that way when i have some thin material I just grab the spool gun,(much better than changing those big spools to .023 and then back to .035). If the material is bigger I grab the Mig gun that has the .035 wire. That gun on demand feature is great. Also the longer reach with the spoolgun is a plus and saves having to move the welder at times. Just my opinion.
Harold
Harold
Craftsman Colormatic AC
Victor Journyman Setup
Syncrowave 180 SD
MM210 With Spoolgun
Spectrum 625 Plasma Cutter
Miller HD Tape Measure
