Does anyone use Millers PC-300 Pulsed TIG (DC GTAW) Control unit? I keep hearing about the benefits of pulse and was wondering if the 300 pulse control unit would make my 180SD pulse/operate as well as machines that come with factory installed pulse? Thanks
Can be used with AC or DC welding power sources with, or without, built-in HF or with external HF units (HF-251D-1 or Snap Start II). Non-inverter power source uses 0.5-20 pulses-per-second. Inverter power sources uses 0.5-20 or 10-300 pulses-per-second.
