Welding table
  • Welding table
    I recently built a 24 by 36 welding table for my Tig and Mig projects. The Metal Supplier wanted over a hundred bucks for a piece of new 3/8 plate 24 by 36 inches. The sold me a piece of scrap the same size for about $30. I have tried to clean it off with a grinder and a wire brush. I have also tried Naval Jelly twice. The plate is now reasonably clean ie bare metel here and there and a thin coat of dark brown rust. You can run your hand over it and no rust comes off.
    When I weld on it I get a little arcing here and there. Also some of my Mig welds seem to be more contaminated then they were at school. I haven't tried any Tig on the table yet. My question is how clean does it have to be? Anyone know of a good way to clean it further?
    Thanks
    W. Hatter
    One thing you might try to clean your table are sanding wheels for your grinder. I find that they really create a nice smooth bare metal finish. I use them all the time and I love them. They will take all the rust right off. Try and keep chemicals off of your table because they might get in and contaminate your welds, but I think surface prep on your weld joint is the most vital for getting the contamination out of the welds. Make sure thats really clean.
      whatter,
      I've had good luck with 36-grit sanding disks on my 5" air sander. Flap-disks work well also on a drill motor. I'm sure you can also get appropriate disks for a 4-1/2 angle grinder.
      My table is exactly like yours - 3/8 scrap. I cleaned it up with with the air sander and 36-grit. Another possibility is take the piece to a machine shop and have them mill .001 off it, but I have no clue what that may cost.
      Be well.
      hankj
      ...from the Gadget Garage
      Millermatic 210 w/3035, BWE
      Handler 210 w/DP3035
      TA185TSW
        whatter,
        I must agree with mlicoasty that weld prep is the key to a clean sound weld. I have 3 welding tables: 2 are 1/8"x24"x24" mild steel tops with 1"x1"x.125" square tube legs and frame. The other is a 19"x31"x 3/4" T1 top on casters. For MIG or stick I am not too particular about the table prep, but sometimes use a clean backing plate of sheet copper of carbon. For TIG I always use a 12"x1"x1/2" carbon plate on top of my weld table and my work goes on top of the carbon block.
          If you could find somewhere local to get it sandblasted that would get it clean. I would hate to guess about the cost though, it could go either way. I would ask around.
            Seven or nine inch sidegrinder with a knotted wire brush, wear safety glasses and face shield.
              Welding Table
              I guess I'll try and purchase a sanding wheel for my 4 inch grinder. The bottom line is that I will probably use up the money I saved in hard labor. But that is the way it seems to go.
              By the way I made the table from 1 1/4 inch angle and 2 inch flat stock. I made it 28 1/2 inches tall and put it on casters. That way I can sit down when I Tig. I am lazy!
              Once again thanks for all the good advice. I need all the help I can get and there seems to be alot of experienced people helping out with this board.
              W. Hatter
                whatter,
                I sit to TIG whenever possible. That is not being lazy. That is the first rule of welding: BE COMFORTABLE!!!
                  HAWK:
                  BE COMFORTABLE! now you sound just like my teacher his first rule is comfort in welding position. We all work better, longer, faster, and fatigue less, when we work in a comfortable position. I am not ashamed to say comfort rules.
