My unit is the Pirhana P-50 and that unit handles anything I can throw at it. I tried the others at the PRI show and am fond of the P-50. When comparing the same hole size in a common plate size, the Pirhana didn't "grunt" nearly as bad. It seemed effortless. The cost difference is quite a bit though (a few thousand$$) and unless you are using it alot, a Scotchman or other less expensive brand or even a used unit would be the way to go.
Check out these links.
Or goto www.netmachinery.com and do a search.
Good luck
Andy
Good luck
Andy
