I finally got a #9 tig torch for the new Dynasty( the #20 water cooler is nor here yet) and tried my luck at TIG. I have played with an Econotig at work and done a good bit of gas welding. First I tried aome .063 mild steel and the weld looked good to me. ( I may not know a good one if I see it). Then I tried some .080 aluminum 5052 and it looked better than expected. Then I tried .040 3003 at 40 amps, 1 pulse per second and everything factory set ( i didnot want to change too many things) I think the weld was pretty good for me. I am enclosing a photo and would like some of you Pros to offer suggestions I will also attach a photo of the rig on the cart with the tank and cooler. I may have to put the photo in a reply
I LOVE THIS MACHINE !!!!
Thanks,
collier
Thanks,
collier
