Hello guys,
I have been working on my AL welding with little or no success. I am using 1/8 on AL and following the tap and speed per the panel on my MM210. I am using .030 wire and gas pressure of 25. I seem to have a common set of problems and frankly I can't figure out what I am doing wrong. The results are either flat wide welds, craters/canyons or burn through. If you flip over the scrape I have more buldging out the other side than I do on the side I am working on. I used what I had around to clean it which was paint thinner, some sand paper and a SS brush. I start off with about an eighth to quarter inch of a bead and then thats all she wrote.
Any ideas or suggestions?
Many thanks
Jorge
Many thanks
Jorge
