Anyone got tip for welding on chrome? I have a chrome bumper that needs the rust removed.
Chrome?
iso50
the chrome must be removed from the area to be welded.. either by grinding it away to clean steel or having it de-plated at a bumper shop.. not sure what you are trying to do here.. are you trying to repair rust pits?? could you give us more info in what you are trying to accomplish???
as a general rule plating should be removed from any metal to be welded before you strike an arc... some plating like cadmium and zinc(galvanize) will vaporize and make noxious/poisonous fumes... chrome.. which is usually triple plated ... one layer of copper.. covered with a layer of nickel.. and then the final plating of chrome...IT will make a mess if you try to weld through it .... and worse... the mongrel alloy that will be produced will not have the strength of the steel that you used to have....
Always clean off the plating from the base metal before you weld...
hope this helps
Heiti.
Iso
if it is not a rare car... you might find it more cost effective to get a replacement... if the bumper is rusted through in some places then it is probably very thin in a bunch of places... you might call some of the bumper and plating shops in your area to find out how much a replacement might cost.. and then weigh out whether it is worth your time and effort...
Hope this helps
Heiti.
