Once more into the fray:
In another thread (sorry, I'm not "board-smart" and don't know how to link a thread - mebbe I getta hep?)I was talking settings on the MM135 with DDA52. I use straight CO2, but the door chart numbers suggest I could weld "hotter" with C-25 - the wire speed is much higher for the Ar mix. What happens with 84/16? Is the gas mix that significant in determining weld parameters? If I can run my wire speed at a dial setting of 60 on a mix, it suggests to me that I can put a lot more heat (i.e. amps) into the weld. True or not?
Educate the uninformed, if you please!
Be well.
hankj
Be well.
hankj
