All my welding has been self taught over many years. The one problem I have not been able to over come is water tight / air tight welds without a small leak somewhere. As an example, I have recently made some serious changes in an engine oil pan for more clearence. When finished, everything looked great. Put it back on the engine and filled with oil, and a very small weep at just one spot.
My air/water tight problems are when MIG welding on thin sheet. I do the tacks every few inches, let cool, repeat this cycle. Then go back and tack in between the first tacks letting tacks cool. FInally when I an down to about 1/2" between tack, I weld in the spaces.
I would appreciate any instruction/tips on how to weld seams in thin sheet, making it water tight/air tight the first time.
Thank You
Paul
Thank You
Paul
