I have some wheels to install centers in (off road ag use). My customer wants the centers made from 1/2" plate and the rims are 1/8". Should I use short arc or spray?
Wayne
I would spray if possible in the flat position and keep most of your heat on the 1/2" material. Practice on a similar setup first. I used to do a lot of spray on 3/8" to 1/8". It is mainly technique. Watch your stick out and run fast!
