Aluminized Exhaust Tubing
  • Aluminized Exhaust Tubing
    I have been using a MM175 for awhile now for auto restoration work. This is one nice machine! I want to fabricate exhaust systems for the cars I restore and will use aluminized tubing. Is there any special prep required such as removing the al coating? I know I will destroy the coating in the weld area no matter what I do but worry that the aluminum coaing will become part of the weld and result in future cracking. I do know that the corrosion properties will not be to good in the weld area.
    Thanks, Rene'
    Rene, I used to weld aluminized sheetmetal daily. There is no difference then welding bare steel. We just sprayed the post weld area with cold galv spray..Bob
      Thanks Bob. Also thanks for the cold galvanize spray info. Rene'
        what part of ct . are you from ?
        brian, northern fairfeild county !!
          Brian, Sorry I didn't see your reply, been out of town. I live in Tolland, Ct way up north in the woods! - Rene'
