Your gas setting can varry depending on your enviornment, air movement, inside, outside. I've found that I turn the pressure down to the point where the steel weld starts to get bubbles and then go up a little from there. If it's windy you will need more pressure. It takes me 2 hours round trip to fill a bottle so I try to conserve my gas and all welders and regulators will need a little different settings anyway.
