I have a hobart handler 175 and can't find a extension cord for this unit, does anybody know where I could order one or do I need to make one up myself???
extension cord
magnum 21,
I saw a pre-made ext. cord on ebay not long ago.You could check there. If it were me, I'd just make my own. Who knows, may end up cheaper in the long run.Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
Ext. cord
Magnum21,
You don't say how far you want to get from your receptacle, but if your best effort does'nt net you a factory made cord in your neck of the woods, you will be fine fabricating your own cord from #10/3 SO wire and the appropriate ends from your local electrical supplier. You can probably go 100' without a problem, but I would be looking at #8/3 SO wire over 50' if $$ are OK.
Be well.
Hankj...from the Gadget Garage
Millermatic 210 w/3035, BWE
Handler 210 w/DP3035
TA185TSW
http://www.brwelder.com/indexTemplate.cfm
http://www.weldingdepot.com/?source=overture
You will be fine with 10/3 on the 175. Its only a few $ more to get the 8/3; then you would be set fora larger welder in the future. I got mine from Welding Depot before I saw them at BR. Prices are the same either way. It is cheaper to buy made up.
Extension cord
I made my own 50 FT cord using 6/3 SO wire. Made a box at the business end that has two different 240 VAC outlets and four 120 VAC outlets. With this set up I have power available for my MIG, stick welder, grinder, fan etc., with one cord.
If it is one thing I don't need in the work area, it is a bunch of trip hazards. I'm a one man accident looking for a place to happen.
moe1942
wrench
I do have a tractor supply by me but the problem is the end has a parralel plug with a round ground and all tractor supply has is a 1/2 moon ground
everyone else I appreciate the responses and will probably get the cord made up at Br
thx
