wire feed speed tracking
  • markcusp
    Thanks for the response Andy. That's pretty much what I figured. I guess I will play around a little more with it and see how it goes. Maybe someone else out there can give some feed back on this function.
    From reading your posts I can see you are a real asset in this group and look forward to reading and learning more.
    Thanks again!
    Mark
  • ASKANDY
    Mark,
    Welcome to the site!
    Wire speed tracking usually makes things easier. When you get the unit welding where you like it and want to move to a different thickness, just change the voltage. The wire will increase or decrease with the voltage adjustment. You may only have to change the wire setting just a little to fine tune.
    Most people think this is an advantage and I have not heard any problems from it. Would like to hear from anyone who has though.
    Thanks for the question.
    Andy
  • markcusp
    started a topic wire feed speed tracking
    Hi all !
    I just started using my new MM135 and was wondering what problems or advantages the wire feed speed tracking system gives you. So far I have only put flux core wire through it and it welds nicely.
    Was a bit surprised that the owners manual does not even mention this feature. Also I have read on other groups that some have had trouble with this "wire tracking". So any 'heads up' on this would be appreciated.
    Mark
