Both are great for mobile work. Each unit performs great on the Trailblazer because of the Line Voltage Compensation circuit. If you have 10KW generator on your engine, go for the 2050. I run mine from the TB301G and clean cut 7/8" with a 1" sever. The 625 maxes out on a 5/8" clean cut and just a bit larger sever. For mobile work with the Trailblazer the 2050 is worth the money. It also has Auto-Line allowing it to run on any power from 208-575 1 or 3 phase. These figures are plus/minus 10%. I have used both and the biggest difference is the cut capacity and the Auto Line feature on the 2050.
