I'm starting to do a little research on buying a plasma cutter and have a couple questions. (Don't want to buy the wrong machine) I normally would use the machine to cut 1/4" and 3/8" thick mild steel. I do ocasionally cut 1/2" mild steel plate 24" x 24" with some smaller square 4" holes cut in it witch brings me to my question. When starting the cut on these 4" squares would you drill a hole in the corner of the square or just make sure your machine can pierce that thickness of material?
Plasma Cutters
Spectrum 625 seems like the machine for what you have described. I know we had a few questions on P cutters so you may want to use the search function on the board and see who has said what about.
I have an old second hand P cutter and while I am not cutting the thickness you are I don't find myself needing to drill anything. My biggest problem is keeping my hand steady but thats because I dont have the right work set-up just yet.MM210 w/3035
Next up - Sync 200
I've had my Spectrum 625 for about 6 weeks and I am still learning. I haven't cut any plate that thick but I have pierced 1/4" and there was nothing to it! you just aim the torch at an angle and blow the metal out till you penetrate much like you would do with a gas torch. I cut a lot of 1/2" bolt heads off ( 3/4") and I just start on the side and wash them off. Once the arc starts the torch shoots out a flame almost an inch long. I am very happy with the 625, I used a plasma 10 years ago but only for a short time so you might as well say I have no experience. I have burned a lot with a torch and they are simular but plasma is faster. Also neat feature, to cut a straight line on plate just grab a 2X4 for a straight edge. Cuts so quick it barely burns the wood. You do need a decent compressor for the 625. I have a 5HP 2 stage so I have plenty of air but I can see how you could work a smaller one.
