I was curious if anybody has come accross the following:
Setup:
-mm250(new)
-single ph 220v
-wire-shieldbright .035fluxcore 316L
-gas-argoshield 25c (75/25)
-ws 470ipm, 22.5v, 25cfh gas
-cup slight drag
-flat overlap fillet .250 mtl thickness
The problem we're experiencing is a surface imperfection that appears to look like a "worm". This is on the surface, when ground out there isn't any porosity adjacent to this area. This is not something we see on every weld. It will occur at random. Wind is definitly ruled out. The material is clean. We are in the field using customers machine/consumables. I do recall this same problem at our shop, but credited it to our aging equipment using .045 flux T91 with Co2 also. It seems more common with the larger wires. Is it because we are running on the outer limits of voltage/wire speed? Would a tri mix help? What about the T91? We are not dragging the cup. What is the technical explanation for this? Any help is appreciated. Thankx.
Setup:
-mm250(new)
-single ph 220v
-cup slight drag
