Let a friend of mine use my 375 extreme and apparently he noticed water coming out of the nozzle. His ignorant self though that's how it worked, like a water jet. He never drained his air compressor and it had plenty of water that carried over. So I get it back and I'll hit the trigger and the pressure light will come on. After I pull the trigger a few times, it will eventually work. I'll use it for about 5 min or so, set it down, then try to start cutting again. The same thing. Sometimes it will work immediately, sometimes I have to pull the trigger a few times, get that puff of air out the nozzle (the small amount of air you get when there isn't enough pressure), then it will work again.
I have a new filter on order for it. Is there anything else that I can take apart to clean (regulator, solenoid, etc). From the look of that water that was blown out of his tank, that's what passed through my machine.
