New here need some help I use this machine every day and when it gets 2-1/2 gallons low on fuel it starves under welding load. fill it back up no problems does great ? Any suggestions would be appreciated thanks.
Miller 225 NT fuel delivery problem
Not really familiar with the machine, but it sounds like a typical in tank fuel pick up line problem. Either it has a hole in it part way down in the tank or has come apart part way down in the tank. In effect you have a short pick up fuel line in the tank. That is my guess from what you describe.
The pickup tube acts the Same as a fountain drink straw when it cracks half way and u begin sucking up air. Pull out the hose and replace the section of tubing ..
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
