arcmaster 185 setting help.?
I guess we did I just got a chance to weld some aluminum today . Got it all figured out if some one else need some quick set up setting I wrote some down after hrs of figuring out the parameters. I like being able to fiddle with all the setting but its also a chore I haven't set up a dedicated station for this welder so I only pull it out when I have some aluminum tig to do.
Originally posted by eecervantes83 View PostIm having trouble setting up to tig aluminum for some reason all the parameters seem backward upside down and I cant put down a decent weld yet. Im using 2% lathanaded. 3/32" at 150amps. What are some starter setting on this machine ?
on a Sync or Dynasty a balance setting of 70 means 70% Electrode Negative
But on the Arcmaster it means 70% Positive...
See "WAVE BALANCE" on page #27
http://victortechnologies.com/IM_Upl...430429-503.pdf
BTW... Didn't we go through this over a month ago..??...
http://www.millerwelds.com/resources...anyone-own-one
.Last edited by H80N; 09-12-2015, 04:58 PM.
Im having trouble setting up to tig aluminum for some reason all the parameters seem backward upside down and I cant put down a decent weld yet. Im using 2% lathanaded. 3/32" at 150amps. What are some starter setting on this machine ?Tags: None
