Im having trouble setting up to tig aluminum for some reason all the parameters seem backward upside down and I cant put down a decent weld yet. Im using 2% lathanaded. 3/32" at 150amps. What are some starter setting on this machine ?
arcmaster 185 setting help.?
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
Originally posted by eecervantes83 View PostIm having trouble setting up to tig aluminum for some reason all the parameters seem backward upside down and I cant put down a decent weld yet. Im using 2% lathanaded. 3/32" at 150amps. What are some starter setting on this machine ?
on a Sync or Dynasty a balance setting of 70 means 70% Electrode Negative
But on the Arcmaster it means 70% Positive...
See "WAVE BALANCE" on page #27
http://victortechnologies.com/IM_Upl...430429-503.pdf
BTW... Didn't we go through this over a month ago..??...
http://www.millerwelds.com/resources...anyone-own-one
.Last edited by H80N; 09-12-2015, 04:58 PM..
I guess we did I just got a chance to weld some aluminum today . Got it all figured out if some one else need some quick set up setting I wrote some down after hrs of figuring out the parameters. I like being able to fiddle with all the setting but its also a chore I haven't set up a dedicated station for this welder so I only pull it out when I have some aluminum tig to do..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
