Members,
This may not be an appropriate question for this forum, and if not I'm sure you'll let me know!
I wnat a bench grinder that does not have that motor in the way of the work on one side of the wheel. I'm going to build a mandrel-type unit with an 8" wheel on one side and a cable-twist wire wheel on the other for joint prep 'n stuff. Ought to be a fun rainy-day project to build it all: tool guards, dust collection, the whole act.
My only delimma is what motor to use. Capacitor start or split-phase induction? I like the quick, high-torgue starting characteristics of a capacitor start motor, but almost all the bench grinders I've ever seen are split-phase units. Also, what do you think of using a 1725 rpm motor with a larger drive pulley vs. a 3400 rpm motor and the same size pulleys on the motor and the mandrel?
As always, you opinins are valued.
hankj
hankj
