Used Shopmate 300
Yeah, tell us who is giving out free Millers LOL
You could pick up a short run of wire at HD or an electrical store. Mine is on 50amp plug but you can wire directly if you prefer. You will need a big circuit breaker if you are going to run at max capacity, though it seems most run a smaller breaker, at lower welding amperage.
Used Shopmate 300
Used Shopmate 300
Why can't I ever find a free shopmaster 300?
Probably best to use your serial
number to download the manual for your machine from the Resources tab on this page if you don't already have one. That would give you a Miller part no. For the power cord which you can likely order from Miller4less.com. If you are knowledgeable of electrical work you could easily make one or have an electrician make it up for you. Assume you have adequate 230v power where you plan to use the machine?
Used Shopmate 300
Hey folks, just picked up a used Shopmaster 300 and i've got to do some troubleshooting on it but it was free so i can't complain. The power cord isn't there so i was hoping to find out where to pick one of those up. Anyone? Thanks for the help in advance.Tags: None
