Welding 18 guage dirty pipe
  • Welding 18 guage dirty pipe
    How do you weld painted 18 guage pipe?
    Clean it first.
      Don't have time to clean it. My job works on productively we dont have the time to clean everything we work on.
        If you do not have time for adequate planning and preparation... you will get a garbage result.... clean and prep it first.... it will take less time in the long tun
        Do you have time to tell us what type of metal ... where..??? and what process & equipment you are using..??
          Is this for a product for sale on the open market? What company?
            Some guys swear by Nonobtanium filler… but it is about impossible to get….
              I have a few 1109 rods stashed away.
              Miller stuff:
              Dialarc 250 (1974)
              Syncrowave 250 (1992)
              Spot welder (Dayton badged)
                Those 1134 rods would do the trick too, but you have to turn H3LL upside down to find it!��
                Millermatic 350P
                30A Spoolgun
                Lincoln Pro Mig 140
                Hypertherm Powermax 30
                14" Rage Evolution dry saw
                40 ton press brake
                Evenheat Heat treat oven
                1x42 / 4x48 belt grinder
                  I do that al the time buts its usually after it leaves the engine.
                    I have to weld thin wall duct work sometimes at work, and even after cleaning the galvanization off, it is still "dirty" so to speak. I have found using .030 cored (no shielding gas) works well. I have the ability to use either Pulse or Mig Mode and choose the latter.
                    I tried a few other things that did not work so well. Using a variety of shielding gasses only produced more spatter, and pulse welding in several configurations made the arc rather unsteady. I did try several pulse configurations to get the background arc to hold, but ultimately had better luck in MIG Mode.
                      Have you tried using unobtanium? Or try magic....either should work.
