S -74DX ce wire feeder code lock.
  • S -74DX ce wire feeder code lock.
    Hello, I was playing around with some of the code lock settings on the miller S -74dx wire feeder and I accidentally locked myself out.I tried factory resetting according to the manual by pressing program, sequence, upper display, and setup simultaneously but it would not bring me to the reset menu. I don't know if this is possibly because I locked myself out or what.I'm stumped and any help would be greatly appreciated.Thank you.
    Bump
      Welcome to the forum.
      Lincoln A/C 225
      Everlast PA200
        Thank you
          Serial number PLS...
            Not sure why serial number is needed unless the unlocking procedure is somehow dependant on it but it starts with ME if I recall.
            Thanks
              My guess is that he's going to look up the manual for your exact machine and try to help you solve your problem.
              But I could be wrong.
              But I bet I'm not.
                The reset method for this newer model of the 74DX feeder is a little more complicated than the older version to help make it more secure. I can help you get it unlocked, but you will need to call in to our phone support as I can't put the complete reset procedure on here.
                Please give us a call at Miller between 7:00am and 5:00pm Monday through Friday at 1-866-931-9733 and ask to speak to the Industrial Systems Group and we can take you though the steps to fix your feeder.
                  Thanks Blue_Tech.....!!.........
                    Thank you everyone.
                      Is keeping the reset procedure a secret to combat theft of these things, or to is the lock out to keep operators from messing with settings? Just curious as I have never worked with a feeder like this.
                        keep operators from messing with the settings
                        Ed Conley
                        MM252
                        MM211
                        Passport Plus w/Spool Gun
                        TA185
                        Miller 125c Plasma 120v
                        O/A set
                        SO 2020 Bender
                        You can call me Bacchus
                          Were you able to get your feeder unlocked...??
                            Thanks for the clarification broccoli.
