Hello, I am working on a project for a customer who needs to join a 409 stainless tube to a stainless casting. The original prototypes I made were very successful by doing a GMAW bronze braze with ERCuSi-A using a (Miller) Panasonic TAWERS robot with brazing software. These prototype samples were ultimately rejected because these specific tubes transfer an acid that eats away the copper material. The customer has now specified BAg-24. We currently only use BAg-24 with induction brazing but we want to avoid this process as the joint is very difficult to induction braze. Is there any way to robotic braze silver with the GMAW process? If there are no silver options, are there any other GMAW wires that would be suitable to join these materials on a robot. Welding or brazing. To take it even further, does anyone know why you can GMAW braze brass, bronze, aluminum, but not a silver alloy?
Does Silver brazing with a GMAW robot exsit?
Why "braze"? This data sheet discusses welding:
"The electrode wire most often suggested is an
AWS ER309 or ER308L austenitic
stainless steel when the applications
do not include exposure to high temperatures. AWS ER309 or ER308L stainless
wire may also be employed for
joining 409 stainless to mild steel. Thin
wall components for elevated-temperature service should be weld fabricated
with a matching weld filler such as
409 Cb. AWS ER430 and W18 Cr-Cb filler
wires are suitable alternatives."Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
