we run co2 for gas at work. I just bought a 252. everything is brand new. having trouble finding a good smooth setting. ive tried the settings miller gives but those are not even close to where it should be. I had a 251 before. I used to have that one set at 19.5 and 217 or 220 and that would burn perfect. very smooth. now ive tried those same settings and any settings close to that on the 252 but it just doesn't run as smooth. any thoughts
using co2 with 252
I know that on the MM350P you can adjust the inductance through the "Arc Control" and that will allow you to run beautiful nearly spatter free beads with CO2...
And my old MM200 will run nice beads on CO2 with no available inductance control at all...
Do not know the secret for the MM252....
might try to clean your metal a little better and play with your voltage a bit...
Apparently CO2 is much more sensitive to wire stickout... so you might want to watch that as well..
Ran across one of Jody's vids on CO2 that might be useful too... even though it looks like you have no inductance control...
http://www.weldingtipsandtricks.com/...lding-co2.html
Here is an Irish vid that gives some gas nozzle to contact tip ideas.. for CO2
https://www.youtube.com/watch?v=XgfjO_SR1So
On welders without an adjustable inductance...
some folks will add an inline precision calibrated and wound auxiliary inductor like the one illustrated in the attached pic
(Courtesy of BUBBA-Tronics)Attached Files.
Hello. You mentioned 21 Volts and 217 wire speed? Sounds like your wire speed is too slow. I have a near new 252 (2013) and I run straight CO2. It welds smoothly at all settings but you do have to keep the wire speed up.
I also experimented with the tips. The original tip was flush with the outer copper cover and I did have some problems with the wire sticking. I read up on the issue and bought and outer cover that recesses the inner tip 1/8" and that solved the problem. The 252 is a wonderful machine but I liked all of them all the way back to the 200. My friend has a MM200 that is at least 30+ years old and he uses it nearly every day with great results.
You might also want to re a system reset as outlined in the factory manual.
Good luck and don't give up.Last edited by Synchroman; 08-22-2015, 05:49 PM.Miller Syncrowave 200
Milermatic 252
Lincoln AC/DC "Tombstone"
