thunderbolt 225
What's the part number?
thunderbolt 225
Before you buy a new one, is it possible to clean up the contacts in the old one & maybe bend them for a little more tension?---Meltedmetal
thunderbolt 225
hey again I want to thank everyone for their input I found the switch and going to order it next week its 102.00 plus shipping but that's a heck of a lot cheaper than a new welder
thunderbolt 225
So no flux capacitor or electrical skookum drives? That's good. Glad you got it figured out. I had a switch break on a run of the mill lincoln stick machine break years back. It was obvious what it was, so I just had the LWS order it. Dadgum thing was $35 and when it came in, it was nothing more than the same dern thing I could've picked up at a hardware store for $5. If that much! Dang vultures.
Outstanding! If you need to buy a new switch look at Miller4less.com
just enter the part number from your parts list.
thunderbolt 225
hey gentlemen found it . it is the switch that changes the voltage on the front my nephew came down and after a lot checking and tightening we got to fooling with the voltage switch and got it arc so I figured I would replace and that will cure my problem I wish to thank everyone for their response the advice was a great help
thunderbolt 225
well I found a wiring diagram for the ac/dc 230 volts so im fixin to go see if I can trace this problem down like everyone has said this aint nuclear fusion will let u know what I find and again thanks people
thunderbolt 225
I would absolutely love to have 460v out in the shop. That would totally rock.
Really need the info from the data plate. The manual shows a 460-volt version that is not adaptable to 230 v. Hope that's not the problem-not many of us have 460 in the garage!
thunderbolt 225
Ya, you're probably right. Nothing near the nuclear fusion or atom smashing level of difficulty. The only machine like that that I've ever seen fail (I'm sure there are others, so don't anyone go beating me up), did so because of mechanic damage. Seems like it got backed over by a forklift or something. So, unless he's a really bad forklift driver, I think we can help him at least determine if it's a salvageable piece of equipment.
Originally posted by ryanjones2150 View PostMy machine is a lot older than that one, which is probably why it still works. Even so, can't be a whole lot of things to check in there. I could be wrong though. Yours might have a miniature nuclear reactor inside.
thunderbolt 225
Looked at the manual-Going to need a photo of or all the info from the model/ serial number plate. There are multiple versions covered by this manual with diff connections inside. Could not find any info online from the stock number.
