My Dynasty was manufactured in 06 and I have owned it since 08. Recently it has started to act up after about 3 min of use. I took it in to Matheson Electric to have it diagnosed. The tech there told me that the inverter control card (board) part # 207822 has failed. New cost of board $1250 plus an hour labor. On top of this it may need a Boost control card part #200841. I was told the first card has to be replaced before it can be tested further. I did not get a price on the Boost control card as I was sickened by the thought of the first quote of around $1350. As I was searching for the #207822 I came across a replacement part SKU of #230187. Does anyone know if this is an improved board that has a better design than the previous # or is it even compatible? Or should I just cut my losses and go with a new machine?
Need repair advice on Dynasty 200DX
Originally posted by gearguy View PostMy Dynasty was manufactured in 06 and I have owned it since 08. Recently it has started to act up after about 3 min of use. I took it in to Matheson Electric to have it diagnosed. The tech there told me that the inverter control card (board) part # 207822 has failed. New cost of board $1250 plus an hour labor. On top of this it may need a Boost control card part #200841. I was told the first card has to be replaced before it can be tested further. I did not get a price on the Boost control card as I was sickened by the thought of the first quote of around $1350. As I was searching for the #207822 I came across a replacement part SKU of #230187. Does anyone know if this is an improved board that has a better design than the previous # or is it even compatible? Or should I just cut my losses and go with a new machine?
loosen and retighten the dinse connectors
snug all the boards down..
and do a reset to factory defaults just for good measure..
then see how it behaves..............
Go to section "5-17. Resetting Unit To Factory Default Settings"
in your owners manual..
if you do not have one... it can be downloaded here
just plug in your serial number..
EDIT: See you found it while I was typing... but will leave this up for the benefit of others laterLast edited by H80N; 08-19-2015, 09:52 PM..
Well I didn't have anything better to do so went out and reseated the boards, connectors to the boards and the backed off and retightened the terminals that were bolted on and still no go. The inverter board looks good with no burn marks or obvious broken connections but somehow it is faulty.
Originally posted by gearguy View PostWell I didn't have anything better to do so went out and reseated the boards, connectors to the boards and the backed off and retightened the terminals that were bolted on and still no go. The inverter board looks good with no burn marks or obvious broken connections but somehow it is faulty.
CRUIZER is our resident repair wizard... hope he sees this thread.
It started out as it worked fine for 30 minutes then no arc in AC or DC. Then gradually the time that it took to malfunction became less and less. If I let it sit a while it would function properly for a few minutes. Before I took it in it only would arc for maybe 15 seconds. Now that I picked it up from getting it tested no arc at all. The solenoid kicks the gas on but no arc. Machine sounds normal as in full of bees is my best description. I was just going to purchase a new board but if you guys don't mind helping me verify that it is the inverter board I really appreciate it. I have a UEI Ohm/volt meter but don't know where to test things.
Bump...
Originally posted by gearguy View PostAny ideas anyone?
Maybe if we bump this he will see it....
I've been thinking of taking it somewhere else that can give me a solid quote instead of saying we need to fix this first and then see if it needs something else. According to Miller that's how it's suppose to be done. Unless someone here can help me trouble shoot.
Originally posted by gearguy View PostI've been thinking of taking it somewhere else that can give me a solid quote instead of saying we need to fix this first and then see if it needs something else. According to Miller that's how it's suppose to be done. Unless someone here can help me trouble shoot.
here is their main number they can connect you
Phone: 920-734-9821
Here is their contact page
