Nitrogen gas suggested as a purge for welding a stainless nozzle to heat exchanger. So I thought I would use nitrogen in my torch too. Doesn't work with torch at all. I got nervous and switched the purge to argon before I buggered the job. Rumor is if I keep the gap small and the arc doesn't get near the purge, I would have been ok? Can anybody give me the straight goods with regards to using nitrogen as a welding and/or purging gas for stainless welding?
nitrogen purge
Originally posted by Azphiks View PostNitrogen gas suggested as a purge for welding a stainless nozzle to heat exchanger. So I thought I would use nitrogen in my torch too. Doesn't work with torch at all. I got nervous and switched the purge to argon before I buggered the job. Rumor is if I keep the gap small and the arc doesn't get near the purge, I would have been ok? Can anybody give me the straight goods with regards to using nitrogen as a welding and/or purging gas for stainless welding?
Becoming more popular as a SS backpurge....
Use to use nitrogen as a purge gas, butt the PEI dept. stopped it, said it caused cracking,,,, never used on the torch, it won't work. The shops use to use the nitrogen because of price, but you have to use more to accomplish the same purge as argon, so it works out in the wash to just use argon, IMHO. Plus you can't use out for nickel base alloys, it won't do the trick.pull-do
Originally posted by blazehaze69 View PostI don't believe nitrogen is an inert gas...
John
Here is an AWS article worth reading on the subject
https://app.aws.org/wj/supplement/WJ_1975_01_s12.pdf
Here is a very good overview of backpurging gasses and techniques
http://www.boc-gas.com.au/internet.l...e351_68116.pdf
.Last edited by H80N; 09-07-2015, 03:34 PM..
If I'm correct, the main issue with using Nitrogen as a purging gas is the possibility of the diatomic Nitrogen molecule (N2) coming in contact with the electric arc, presumably if there is a slight gap in the joint. N2 is not soluble in the molten weld pool, but if it comes in contact with the electric arc it dissociates (separates) into monoatomic nitrogen atoms, which are soluble, and diffuse into the weld pool causing nitrogen embrittlement. That's only from what I've read researching the subject.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
Originally posted by OscarJr View PostIf I'm correct, the main issue with using Nitrogen as a purging gas is the possibility of the diatomic Nitrogen molecule (N2) coming in contact with the electric arc, presumably if there is a slight gap in the joint. N2 is not soluble in the molten weld pool, but if it comes in contact with the electric arc it dissociates (separates) into monoatomic nitrogen atoms, which are soluble, and diffuse into the weld pool causing nitrogen embrittlement. That's only from what I've read researching the subject.
did you get a chance to read the "White Papers" that I linked...??Last edited by H80N; 09-07-2015, 07:06 PM..
Not yet, been up-n-down all day today, lol. I'll have a good sit-down tomorrow and read them in their entirety.HTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
Talking about Argon...
I thought I'd put this in for the heck of it...
I bought a tank of Argon from a neighbor. The label was sort of crappy looking, so I thought I'd do a little checking. I ruled out that it was C25 buy bubbling some of the gas into a beaker of distilled water. I checked the pH with a meter my wife had- she's a retired chemist- and the pH remained around 7.0...
I did the same test with a tank of C25, and the pH went down to around 4.5...sigpic...John
Lincoln SP135 Plus
Victor O/A outfit
Dewalt chop saw
US Navy '65-'69
Tonkin Gulf Yacht Club
USS Intrepid '67
Originally posted by blazehaze69 View PostI thought I'd put this in for the heck of it...
I did the same test with a tank of C25, and the pH went down to around 4.5....
Originally posted by H80N View PostWhy not try to TIG with it and see if it is OK or if it eats Tungsten....??sigpic...John
Lincoln SP135 Plus
Victor O/A outfit
Dewalt chop saw
US Navy '65-'69
USS Intrepid '67
Originally posted by blazehaze69 View PostLess time consuming and a bit more scientific...
ALSO... what color is the bottle..?? and whose name is on the collar..??Last edited by H80N; 09-11-2015, 10:29 AM..
Originally posted by H80N View PostMaybe simplistic but effective... reading that tungsten could tell you lot
ALSO... what color is the bottle..?? and whose name is on the collar..??sigpic...John
Lincoln SP135 Plus
Victor O/A outfit
Dewalt chop saw
US Navy '65-'69
USS Intrepid '67
