Besides millers solutions what else can be used safely in reservoir, have been told dis water mixed with propylene glycol. The glycol I am talking about is envir. safe and we use in heating systems, thanks I am new to this sorry if this is a dumb question. Just cant see spending $25 dollars a gallon if something else will work just as well also heard RV antifreeze. I also plan on taking tig torch inside during the winter months and draining the coolant tank gain thanks.
water cooled tig solution
I'm using pink RV antifreeze from Walmart (supertech). Other than foaming up just a tad in the tank, seems to work just fine. 1 gal rv antifreeze, 1 gal distilled water. Using the HTP Arctic chill cooler.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
Originally posted by OscarJr View PostI'm using pink RV antifreeze from Walmart (supertech). Other than foaming up just a tad in the tank, seems to work just fine. 1 gal rv antifreeze, 1 gal distilled water. Using the HTP Arctic chill cooler.
Read the MSDS it will tell you what is in it..ALCOHOL..
Super Tech RV & Marine Antifreeze
http://ops.americanamb.com/1101MSDS/...Antifreeze.pdf
It used to be OK but they changed the formula
you have a fair sized investment in the welder & cooler... why not buy TIG coolant..?? and protect your investment..??
You might do search... there are many threads on itLast edited by H80N; 08-17-2015, 08:54 PM..
Dynaflux Defense is a reasonably priced coolant. They have a concentrate that you can mix with water. (#929)
http://weldingdirect.com/coolpumlubfo.htmlMiller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
Originally posted by H80N View PostBe careful... some of them have ethanol or methanol...
Originally posted by USMCPOP View PostDynaflux Defense is a reasonably priced coolant. They have a concentrate that you can mix with water. (#929)
http://weldingdirect.com/coolpumlubfo.htmlHTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
