So I just recently purchased a older Syncrowave 350 for 300$. I'm just trying to get a grasp on what I need to do to get it powered up at my shop.Ill most likely just be welding small things as I am new to tig welding.So far I know I have 200 amp Service to the shop. My welder does not have PFC. It needs a disconnect with preferably a 200 amp fuse.I've been reading on other forums and seen people do it in a variety of ways.Would someone please help explain how to go about this. If you're going to say talk to an electrician, don't worry I already got that in mind. I got as far as I set jumpers to 230v, hook it up to a disconnect, then where does the disconnect wire to?SN: KB100192Stock: 902976
Miller Syncrowave 350
Originally posted by aero1310 View PostSo I just recently purchased a older Syncrowave 350 for 300$. I'm just trying to get a grasp on what I need to do to get it powered up at my shop.Ill most likely just be welding small things as I am new to tig welding.So far I know I have 200 amp Service to the shop. My welder does not have PFC. It needs a disconnect with preferably a 200 amp fuse.I've been reading on other forums and seen people do it in a variety of ways.Would someone please help explain how to go about this. If you're going to say talk to an electrician, don't worry I already got that in mind. I got as far as I set jumpers to 230v, hook it up to a disconnect, then where does the disconnect wire to?SN: KB100192Stock: 902976
Here is a link to download your manual
http://www.millerwelds.com/om/o352e_mil.pdf
it has all the link jumpering and hookup info...
This welder wants to see 130amps @ 240vac 1ph for full output (without PFC)Last edited by H80N; 08-15-2015, 07:02 AM..
Disconnect wires to fuse panel. Welder to dissconnect. Distance to fuse panel will determine wire size. If it were me i would wire it to fuse panel with an 100amp breaker.
KevinLincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
Originally posted by ryanjones2150 View Posthow'd you score a syncrowave 350 for $300? I'll give you $350 and a six pack of crappy beer for it right now...
I like how ryanjones thinks!
jasigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
But its probably worth a good 6- pack. Where you located?sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
40 ton press brake
Originally posted by ryanjones2150 View PostBeaumont, TX.
And I give in...$350 and a six pack of good beer..
LoneStar did it, pearl beer did it, probably a few others. Pearl has been out of business since before I was legal though. They had a brewery here in Beaumont, which may be why they went tits up. Probably couldn't get anyone to come to work. Seems like a popular theme here.
Originally posted by ryanjones2150 View PostLoneStar did it, pearl beer did it, probably a few others. Pearl has been out of business since before I was legal though. They had a brewery here in Beaumont, which may be why they went tits up. Probably couldn't get anyone to come to work. Seems like a popular theme here.
I lived in NM for many years...
and while not gourmet/boutique beer...
an Ice cold Pearl on 100+ deg summer afternoon... hit the spot....
Back again. Yeah I got lucky. The person that owned it wanted a new one so here I am lol.
So I went and bought a 100amp breaker for the time being. I wired up the red and black to the breaker, white to common, and green to ground as I learned from my research. Got everything hooked up. It turns on but doesn't weld.
When I press down on the mode switch, a buzzing noise sounds. Like some kind of alarm...
After looking at it closer I noticed the black wire is not connected to anything inside the machine.. is that normal? The red and white are hooked up and green to ground.
This machine was set for 480v previously, i set it to 230v.
Ill upload pictures later.
All Im getting from the circuit diagram is there is 2 hot wires and a ground. The 4th wire is not used?
In the attachment you can see the black wire has a cap on it. In the fuse panel I have the black and red hooked up to the breaker as the hot wires. White goes to common and green to ground.
From what I understand at the moment is right now the machine is just under powered at 115v (hopefully I didn't fry anything.) All I have to do is switch the black wire with the white wire and put a cap on the black wire in the fuse box?
Think that should do the trick? I just want to make sure only three wires are being used.Attached Files
