So I run a miller 251 in my shop. was welding fine then after a lunch it started acting up. both the Ground and the Torch have power running through them at all times. when the machine is turned on attaching the ground to the work piece Causes the gas solenoid to click, there are faint sparks, and wire feeds very slowly. thing happens when I touch a stuck out piece of wire from the torch to the work piece with out the ground.
Any Ideas?
Any Ideas?
