Ok guys I've been welding and fabricating for about 12 years now and my boss wants me to fix some leaks in his pontoon. Welding aluminum is no problem for me but I've never welded on a pontoon and when I googled it it came back with a guy blowing up? This boat doesn't have an internal gas tank and the tanks it does have are off. I know the logs are chambered but it does have drains on the back. Is it the pressure build up from the heat that cause them to go boom? I guess what I'm asking is how do I do the job safely?
New to forum need advice on pontoon welding.
Originally posted by Steel_Surgeon View PostOk guys I've been welding and fabricating for about 12 years now and my boss wants me to fix some leaks in his pontoon. Welding aluminum is no problem for me but I've never welded on a pontoon and when I googled it it came back with a guy blowing up? This boat doesn't have an internal gas tank and the tanks it does have are off. I know the logs are chambered but it does have drains on the back. Is it the pressure build up from the heat that cause them to go boom? I guess what I'm asking is how do I do the job safely?
our resident Pontoon Wizard is "FusionKing"
he has probably repaired more of those logs than anybody out there...and has been very helpful to many
do a thread search on this forum of "pontoon" plenty of good info/threads there
next... post the manufacturer...model and age of the boat...
posting pics of the damage would not hurt either
FusionKing has a FB page you might want to look at....
https://www.facebook.com/OutBackAlum...=page_internalLast edited by H80N; 08-12-2015, 11:18 AM..
This pontoon is a sylvan and the only thing I see on it is G30518 and SYL14737E393. The crack is in the existing weld on the support. After looking at out backs fb page I know it best to fab a new one or cut, patch and reattach. I will try to get picture up soon. My main concern is not blowing up.Attached FilesLast edited by Steel_Surgeon; 08-12-2015, 11:40 AM.
Repairing pontoons
You have nothing to worry about welding on the tubes, I've weled on over 200 of them. It's good they have drain plugs. Remove the plugs. Clean the area very well. I use scotch brite disc to remove the oxides that form on the aluminum.then go at it. If the plugs are not removed when u get at the end of the weld (if u don't have any other leaks or cracks the tube will pressurize and u won't get the end of the weld to seal.) When I get the cracks repaired I put a fitting made I made with a valve stem in it then I add about 3-5 lbs of air in the tube, then I have a spray bottle with soap and spay down the entire tube and look for bubbles. If none are found when u remove the plug u should have air blow back out the plug. Again only 3-5 lbs of air is all u need. Add air then check with a tire gauge . Never had one blow up. Hope this helps. Happy Welding
Welder99
36 yrs in the tradeTrailblazer 250G
Bobcat 225
Miller 150 STL
Lincoln SA-200
Miller XMT 304
Lincoln Squarewave 355
Lincoln 140C
Lincoln 170T
Miller S-22A feeder
Miller 30A Spoolgun
Miller XR-15
Lincoln LN-25's
Hypetherm 380
Trailblazer 302
Spectrum 875
Just to mention a few
Thanks for all the advice guys! I did a little welding on it yesterday evening. Just welded a broken splash guard back on and its a lot different welding on these than what I'm use to. Definitely going to be a learning experience and I look forward to picking all of your brains for knowledge!!
I've built boxes fully enclosed, then band saw them in half to make two. If I get it fully sealed the last puddle will bubble. No excitement like blowing up. I do wonder if some variety of oil slick could seep into a leaky pontoon.Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
Yes shiny and new is what I'm used to. Handrails and small brackets mostly. But I'm not one to shy away from anything. I'll figure it out then grow from there. I think my biggest hurdle is this little miller diversion I have isn't enough to do this kind of work with out a preheat. Or just won't do it I don't really know. The stuff I've done in the past never required it but I also had bigger machines. I'm thinking of investing in a push/pull for my wire feeder but not real sure I can even do that with the setup I have. Again thanks for the advice! All is appreciated!!
Originally posted by Steel_Surgeon View PostYes shiny and new is what I'm used to. Handrails and small brackets mostly. But I'm not one to shy away from anything. I'll figure it out then grow from there. I think my biggest hurdle is this little miller diversion I have isn't enough to do this kind of work with out a preheat. Or just won't do it I don't really know. The stuff I've done in the past never required it but I also had bigger machines. I'm thinking of investing in a push/pull for my wire feeder but not real sure I can even do that with the setup I have. Again thanks for the advice! All is appreciated!!
or getting a bottle of helium mix and run flat out..
which diversion..??Last edited by H80N; 08-18-2015, 10:17 AM..
Originally posted by Steel_Surgeon View PostI have the little diversion 180. Works great on this new aluminum just goes to crap trying to weld it to the log. I'm using pure argon now. How does the helium mix help?
and allows you to weld thicker matl with fewer amps..
kinda like spinach for POPEYE...
here is a video that illustrates it
https://www.youtube.com/watch?v=yhDvRJ7HZ6E
You will have to really clean the aluminum to shiny metal and vee out your crack in any event...Last edited by H80N; 08-19-2015, 11:42 AM..
Originally posted by Steel_Surgeon View PostI have the little diversion 180. Works great on this new aluminum just goes to crap trying to weld it to the log. I'm using pure argon now. How does the helium mix help?Dynasty 280DX
Bobcat 250
MM252
Spool gun
Smith torches
Sorry... I don't get on here much anymore. We have gotten very busy nowadays and I spend a lot of my other time on new adventures(welding and fabbing)
Also I do read the forums when I am stuck somewhere and bored on my phone. For some odd reason the site won't allow me to log on and post. I used to do it all the time. Very annoying because I did it for a good while before it quit letting me on
I'll try to get on the computer more, but to be honest....when I'm on the computer it is all business and I try not to mess around much online unless it's official. I'm just more into the smartphone these days cause I'm on the go.
Not a lot to say here that hasn't already been said. As far as blowing up goes....that was covered pretty well. The way I pressure check is I slowly add air and leave my air fitting a bit loose. Then I spray it (the fitting)... if it will bubble then the leak should as well. I use a long hose with a Ball valve on it so I can add air as I continue to look for leaks. I keep it connected to the compressor, and have a low pressure setting on the line too. It helps to turn everything in the shop OFF, so you can hear for leaks as well.
Some mfg's have fuel tanks IN the logs (plastic) and some ARE the logs. You need to know this before you drill or weld!!! Sylvan does not do this to my knowledge. Harris does on many models.
Naturally the normal fuel tank should be considered as well.
That leak should have the bracket cut off and be patched properly, then replace the bracket. I do warranty repairs for Sylvan quite often and they seem well pleased with the results. Many of the photos on our Facebook Gallery are on Sylvan products.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
