I purchased mine and without doing my homework....bottom line it cost me more money to get set up right. i.e. breaker panel, breakers,but now I'm in the drivers seat lol!
These big welders draw a lot of power(amps), so I recommend anyone that's thinking of buying this machine . To check what they need to run it...
AG
syncrowave 250dx
Nec
Originally posted by Tim cryo View PostWhat wire gauge and fuse protection you would recommend for 220 volt single phase for this welder trouble with AC it is fused 60 amp with 100 amp breaker. It looks like it calls out for 125 breaker not sure on the fuse requirements.
Not sure what you mean by " trouble with AC it is fused 60 amp with 100 amp breaker"
You are correct on the Fuse/Breaker need for this machine to operate at rated output
125amp Fuse or Circuit Breaker on #6 wire if all wiring is done are per NEC Art.630
I know some folks run it at lower output on a 50amp breaker & #6 wire.
syncrowave 250dx
What wire gauge and fuse protection you would recommend for 220 volt single phase for this welder trouble with AC it is fused 60 amp with 100 amp breaker. It looks like it calls out for 125 breaker not sure on the fuse requirements.Tags: None
