Ive been a bit nervous gouging with my XMT 350. my shop is about 400 ft (1awg aluminum) from the transformer and I don't want line voltage drops to hurt the machine. My compressor takes me from 240v at the main down to 230v, gouging at 300 amps pulls it under 210v. Iirc autoline is supposed to cover down to 190v. I'm usually very careful to make sure I only gouge when the compressor is already running but it has started while I'm welding. The voltage drop when the compressor kicks on is pretty bad. I haven't metered it but it's ugly. First question is if I'm alright gouging at 300 amps with the xmt which should be 60% duty cycle. But I'm sure the voltage drop and gouging instead of welding makes that a lot less.
Secondly, do I need to take serious precautions to make sure the compressor never kicks on while I'm welding/gouging with the xmt?
i just checked and I have a lot bigger compressor than i thought I had. 7.5 horse 29 amp.
edit: I'm seeing about 190v when cuts on with 235v at the panel.
this shop is a stepping stone so I'm not looking to upgrade the service here.
