Just got a hold of a thermal arc arcmaster 185 ac dc inverter tig welder. With all the bells and whistles. Wondering if anyone here owns one that can suggest some good setting to begin with. All other tig welders I've ran didnt give me the options this machine has to offer. Most my aluminum tig welding will be on 14gauge.. to 10gauge. What is good setting that work. .
arcmaster 185 anyone own one ?
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
Going to put down some weld tomorrow figured i ask to speed things up a little. If you find out any let me .thanks.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
What settings are you asking about? If you're talking about the AC balance and frequency, then it depends on what you're looking for out of your weld. If you're used to welding aluminum with an older transformer machine, like I am, that frequency adjustment is a huge change. Because I'm so used to the 60 hz, I have a habit of using a similar setting on my inverter machine. Although I have gotten better at trying to use that feature a little more, trying some new things here and there. Grab some scrap and run a few beads while playing with those settings and you'll dial it in pretty quick. That user interface with all the push buttons and LEDs isn't nearly as complex as it first appears.
Originally posted by eecervantes83 View PostJust got a hold of a thermal arc arcmaster 185 ac dc inverter tig welder. With all the bells and whistles. Wondering if anyone here owns one that can suggest some good setting to begin with. All other tig welders I've ran didnt give me the options this machine has to offer. Most my aluminum tig welding will be on 14gauge.. to 10gauge. What is good setting that work. .
It is a neat little unit made by Sanrex in Japan and a real gem.. now out of production .... not to be confused with the current Chinese made units...
Here is a link to download the manual
The only Gotcha on settings is the AC balance...
It is BACKWARDS from the industry norm.... if you set the balance to %65 it will be %65 percent POSITIVE... not negative
See page 27 in the manual
For starters on 10Ga I would try
140amps AC (modualted by pedal)... Rule of thumb: 1amp per thousandth of an inch as a starting point
120HZ Freq
%30 AC Bal (remember it is backwards)
15 CFH Argon
Tungsten-- %2 Lanthanated .. taper ground blunted...
CLEAN CLEAN CLEAN metal
Match filler to alloy being welded
try setting your helmet to 10...
And get your rhythm going...
That should get you into the neighborhood.. adjust from there..
I %100 agree with Ryan.... get some scrap and practice practice..practice..
getting your technique to jibe with the quirks of your model machine might take a little time...
better not to do OJT on welds that matter...Last edited by H80N; 08-08-2015, 09:44 AM..
Good point about the 2% lanthanated tungsten. There are some, including my LWS, that insist on using pure tungsten for welding aluminum. I believe, with the inverter machines at least, pure tungsten is not indicted any longer. I actually use 2% lanthanated for everything, including aluminum on my transformer machine in the drag shop. The only exception is the thoriated tungsten I still use at home, and the only reason I still use it is because I'm trying to use it up so I only have one kind in the tool box. AND I sharpen the stuff to a point, especially when I'm tacking aluminum, then just let the tip ball up however it wants to on its own. Probably not how most people do it, but it works for me.
Pure Tungsten (green) is for transformers only...
inverters like Lanthanated, Ceriated and Zirconiated....
(Thoriated works also but is last on my personal list)
I prefer %2 Lanthanted for everything myself...
If you have not already done so... download the Diamond Ground Tungsten guidebook.... it will tell you more than you ever wanted to know about Tungsten selection and prep...
Thoriated concern leaflet..
H80N no its not the pro-wave.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Here's a pictureAttached Files.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Here's a picture can only upload one at a timeAttached Files.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Originally posted by eecervantes83 View PostHere's a picture
(Wave Balance info the same but on page 29 of the PDF)
here is the service manual
advice from before should still applyLast edited by H80N; 08-08-2015, 01:29 PM..
My first project is going to be welding pop cans together. Ill post some pics when I get started.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Originally posted by eecervantes83 View PostMy first project is going to be welding pop cans together. Ill post some pics when I get started
his settings should be pretty close...
I have never welded cans together, but I have ran a bead around the bottom lip. It's great practice in all areas, torch angle, arc length, etc. You have to have a machine that has a stable arc on low amperage though, that's for sure.
I'm gonna try doing it again using the pulse settings. I have never used pulse on aluminum.Last edited by ryanjones2150; 08-08-2015, 09:08 PM.
