Just bought a trailblazer 325 efi with excel and from the start i have had an issue with it welding about 30 amps hot. The machine only has 10 hours on it. On every other machine ive welded with for 1/8" 7018 i set it within 5 or 10 amps of 120amps and it burns like a dream. With this trailblazer i have to burn it around 90 amps to get decent results. Keep in mind i have welded with dozens of machines including a $10k dynasty 350 set up. All are the same except for this trailblazer. I took it to my lws to get them to figure it out but apparently they claim theirs nothing wrong with it after hooking it up to their amp meter machine. (puts it thought the duty cycle and measures the amps) i just dont see how it can blow holes through plate at 120amps with a 1/8" 7018 rod. Any help form you guys would be appreciated.
trailblazer 325 efi seems to weld 30amps hot
Originally posted by tomconnell95 View PostJust bought a trailblazer 325 efi with excel and from the start i have had an issue with it welding about 30 amps hot. The machine only has 10 hours on it. On every other machine ive welded with for 1/8" 7018 i set it within 5 or 10 amps of 120amps and it burns like a dream. With this trailblazer i have to burn it around 90 amps to get decent results. Keep in mind i have welded with dozens of machines including a $10k dynasty 350 set up. All are the same except for this trailblazer. I took it to my lws to get them to figure it out but apparently they claim theirs nothing wrong with it after hooking it up to their amp meter machine. (puts it thought the duty cycle and measures the amps) i just dont see how it can blow holes through plate at 120amps with a 1/8" 7018 rod. Any help form you guys would be appreciated.
KevinLincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
Hot welder
Check out a older thread that I had about my TB325, it sort'a sounds kinda like mine but not the same.....
I call Miller directly and told them what my machine was doing and after a few call back and forth, not me calling and complaining, both side trying to get this machine fixed, Miller was very helpful to get my machine running they way I liked it, long story short they sent me a new board and BAM..... One of the nicest machine I ever used.
I have had a few pipeline guys use my machine and they love it......
Call miller and ask for Travis Purgett, he is the engine welder division manger very smart man tell him what you are getting and see what they will do for you???
Sometimes the LWS can't do much they are just too small to get results, to many channels to go through, not that they don't try just to many hands in the pot...
Railmen2007 Trailblazer 302G
2004 Invision 354MP
1999 60 series feeder
2005 Maxstar 200DX
2007 CST280
1999 HF 251-1
older Hobart hefty wire feeder
Hyperthrem 600
Maxstar 150S(such a cute welder)
had and sold........
2003 XMT 304CC/CV
1947 Lincoln SA200G short hood
1963 Lincoln SA200G
1975 Lincoln SA200G(best machine ever had)
1970's Lincoln SAE400G
2 Maxstar's 200DX's
1 Maxstar 200SD
CST 280
2 CST 250
MM130
Railmen
